Altera_ForumHonored Contributor14 years agoSignalTap, Nios and netlists Hi, For the last two days I have been trying to set up SignalTap to extract the trace from a nios II processor. I have followed the AN446 application note, but when I compile I get the message ...Show More
Recent DiscussionsTiming analysis - long combinational pathQuartusPro 25.3 Crashed after using the Signal Tap Logic AnalyzerDuplicate_hierarchy_depth / duplicate_registerAutomatically added negative node for TDS output doesn't work with Agilex 5Quartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SG
