SignalTap Invalid jtag (completely wiring dependent)
- 3 years ago
Ouch.
Have you tried slowing the JTAG clock or making sure you have the JTAG timing constraints in your .sdc:
https://www.intel.com/content/www/us/en/docs/programmable/683081/22-2/jtag-signals.html
https://www.intel.com/content/www/us/en/support/programmable/articles/000084236.html
Hi sstrell,
Thanks for your attention.
I've never seen or captured samples mismatch, or no triggering.
My "reliable" means "Invalid JTAG Chain", the device is never more than 60% filled. Meeting timing means no timing error other than unconstrained warnings (those are expected with SignalTap insertions).
Basically, as long as I am able to see SignalTap after programming. I am happy. There is 10% percent chances I don't see it. Tried clean, rebuild. noprune attributes, all sorts. Most of the time, I had to use alternative method or nets to get moving.
