13 years agoI don't think it would create this kind of problem. You can still try to run the timing advisor (from the Tool > Advisors menu) to fix the timing problems (do you have the multi-corner timing analysis turned on?).
Could you show a screenshot showing the scl signal with a bad period? How do you measure the period?
