Altera_ForumHonored Contributor14 years agoSignalTap II does not capture full sample buffer Hello, Whenever I set up SignalTap to have a particular memory buffer (2K, 4K, 8K, or 16K), I am never able to actually capture the entire memory buffer. It seems like I should be able to do t...Show More
Altera_ForumHonored Contributor14 years agoThe pre-trigger part of the buffer isn't filled, if the trigger occurs before.
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
