hghuyho
8 months agoSignalTap hover tooltip differs from waveform value (Quartus 23.1std.1)
Hello, I am using Quartus Prime Standard Edition 23.1std.1 Build 993 (05/14/2024). When hovering over a signal without clicking on the waveform, the value shown in the tooltip can be different from...
RichardT_altera
8 months agoI have not seen this kind of issue before. Does it occur only with a specific design, or does it happen even with a small test design? Or perhaps specific node?
Have you tried upgrading to Quartus 25.1 Standard to check whether the issue still occurs?
If possible, please also try using a different machine.
I would appreciate it if you could share the .stp file along with the data capture so that I can test it on my side.
Richard Tan
