14 years ago
SignalTap and Timing
Recently I have had a design where SignalTap ignores my triggers no matter what trigger I set. Each time I hit Run, SignalTap comes back immediately as if I had no triggers set. That data seems right though.
I am assuming this has to do with timing not met - and indeed I do see that some signaltap signals do not meet timing. Am I correct in this?
Most often I do have signal tap violating timing but it is because I have a number of clock domains being monitored and I do need to see all of those signals. Do you guys have any advice on how to handle this? Do I have to CDC all of the signals I need to capture so that they are all in the clock domain of the clock used by signal tap?
Thank you!
