16 years agoYour problem is not clear. But I observe:
your clk named signal_delayed_2 sounds gated...beware of gated clk problems. your# 1 is ignored in synthesis if your start_signal1 is delayed by 2 clks then it will follow counter by two clks leading to +-2 difference depending on how you are kicking the counter...
