16 years ago
signaltap and mismatch between RTL simulation and signaltap
I am new to signaltap and also had some questions.
I have this code ...
always @(posedge signal_delayed_2 or negedge reset_n)
begin
if (!reset_n)
start_signal1 <= 8'h00;
else
# 1 start_signal1 <= counter;
end
always @(negedge signal_delayed_2 or negedge reset_n)
begin
if (!reset_n)
stop_signal1 <= 8'h00;
else
# 1 stop_signal1 <= counter;
end
My counter rolls over after 2**10
In RTL and gatelevel simulation it works fine and in signaltap and on o-scope it shows different values for start_signal1 (+- 2) from actual values, even though I am feeding a constant pulse to signal which is delayed by 2 clocks for synchronization).
Please let me know if you have ideas/suggestions.
    Your problem is not clear. But I observe:
    your clk named signal_delayed_2 sounds gated...beware of gated clk problems.
    your# 1 is ignored in synthesis
    if your start_signal1 is delayed by 2 clks then it will follow counter by two clks leading to +-2 difference depending on how you are kicking the counter...
    I am getting signal_nodelay (asyncronous to my clock) and then I pass it through 2 flip-flops for synchronizing it to my clock.
    The counter is running synchronized to the clock.
    so if the posedge of signal_delayed_2 occurs when counter = xAA2 signaltap would sometimes report that start_signal1= xAA0 or xAA4 or xAA2 at various samples.
    also wouldn't I delay the assignment of counter to start_signal1 by 1 timeunit after the posedge of signal_delayed_2
    There isn't enough information I am afraid.
    All you have is start_signal1 chasing counter(one register in between). Ofcourse start_signal1 should follow counter by one clk edge. But is your signaltap sampling clk correct and is there anything else driving start_signal1. You better post all your code to see what you have done!
