YousefSherif
3 years agoSignalTab Crashes in Quartus Prime Pro 21.4
When using SignalTab the tool crashes. I found that this error happened when I used pin_AE19 as the input clock to the design. It is 100 MHz. I'm working with Cyclone 10Gx part no. 10CX105YF672E5G...
Nurina
2 years agoHi,
From a past case this problem has been solved by running a new compilation.
Can you try to delete the db files and then run a new compilation to see if the problem happens again?
Nurina
