13 years agoI decided to do it this way because my LUT needs to be reconfigurable, I'm using it to convert 14 bit current samples into 32 bit, the 32 bit result depends on the current range which I want to be able to change if desired. Otherwise you are quite right I would have used a ROM LUT.
