13 years agoThanks for the reply,
No Prune seems to have solved my problem for the moment :). I was setting up an LUT which now seems to be OK under both RTL and Gate level simulation. Gate level simulation takes an eternity though! RE: design errors are you referring to the way in which the design is implemented? Wouldn't I get an error message or at least a warning or info message if that were the case? David
