13 years agoAll signals that have no direct or indirect effect on the design output will be removed. The "useful" signals you refer to would be expected to have an indirect effect on the design output, I assume.
You should consider however the case, that some signals that are thought to be essential for the design are actually ignored due to design errors. Noprune can also keep registers that are meaningless for the design output.
