jaylong's avatar
jaylong
3 years ago
signal tap
I want to output the answers simulated in Signal Tap to a text file. What should I do?
  • Hi,
    try "Create Signaltap List File" in Signaltap file menu.
  • FvM's avatar
    FvM
  • FvM's avatar
    FvM
    "can't use" means what, exactly? The function can be only used, if the signal tap window contains recorded data.
  • jaylong's avatar
    jaylong
    I found out where the problem was. Thank you so much.
  • I believe your inquiry has been answered. Do you need further help in regards to this case?
    Richard Tan
    p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey
  • I believe your question has been addressed. With that, I will transition this thread to community support.
    If you have any further questions or concerns, please don't hesitate to reach out.
    Richard Tan
