MK_ABQ
Contributor
1 year agoSignal Tap Rapid Recompile
Hi all, I am using quartus 18.1 Standard edition. I have enabled signal tap in my design. I added few signals to the signal tap, and also changed the trigger. I understand that I need to recompile ...
KennyT_altera
1 year agoFirstly, you will need to check what devices that you were using.
Intel Quartus Prime Standard Edition software supports Incremental Route with Rapid
Recompile for Arria V, Cyclone V, and Stratix V devices.
Once you identify it support, the Rapid recompile function can be found in:
https://www.intel.com/content/www/us/en/docs/programmable/683552/18-1/trigger-lock-mode.html
https://www.intel.com/content/www/us/en/docs/programmable/683552/18-1/compile-the-design.html
Do let me know if any thing that is not clear in the above. thanks
