MK_ABQ
Contributor
1 year agoSignal Tap Rapid Recompile
Hi all, I am using quartus 18.1 Standard edition. I have enabled signal tap in my design. I added few signals to the signal tap, and also changed the trigger. I understand that I need to recompile ...
sstrell
1 year agoRapid Recompile is only available if you've allocated additional resources for the logic analyzer or if you are removing signals so it will use fewer signals.
The status message seems to be in error, but it would help to know what changes you made to the logic analyzer setup since the last full compilation.
