14 years agoI got a problem.. I write and read to 10 address of SDRAM (address:00_0000h~00_0009h) (data : 0~9). (*attached)
I set the trigger event on the Rising Edge of az_cs (chip select) since it'll work on the read/write request from CPU. (*attached) But the result in LA only run for 6 rising edge of az_cs.(*attached) Can anyone tell me how to run the whole waveform until all of the az_cs wont rise? Thank you in advance Yuyex:o
