BCM1
1 year agoSignal tap: difference between .sof programming
Hi, I am facing issues with quartus prime lite V20.1 and signal tap. When I programm the .sof from signal tap, I have different behavior between different .sof programming, for example: - 1st ....
sstrell
1 year agoWithout knowing what your design is supposed to do or what trigger(s) you've set up, it's not really possible to help.
Can you explain the design and show your full .stp file with the trigger condition columns?
