Signal Tap - Instance not found
Recompiling should have recreated those. However, the best thing to do now would be to just recompile from scratch.
Close the project, delete the qdb folder, and recompile.
Thank you for your reply.
I deleted and reinstalled quartus pro 18.1 and then deleted the qdp folder and recompiled. I can now used Signaltap.
Thank you very much for your help in resolving this issue
For future readers that have this problem try the following:
1) ensure that you have a basic timequest SDC file: https://people.ece.cornell.edu/land/courses/ece5760/Quartus/TimeQuest_sdc_file.html
2) recompile with the new SDC file added to the project and ensure that there are no timing issues (especially with signal tap clocks)
3) If the above does not work, close quartus and the project, delete the 'qdp' folder. then re-open and recompile.
4) if this still does not work, uninstall and reinstall quartus (not as messy as you might think), remove the qdp folder, then re-compile.
I hope this helps future users.
James
- sstrell5 years ago
That's the qdb folder, not qdp.
- anonimcs1 year ago
Contributor
As a fellow developer who's seen the same error on SignalTap (on QPP 21.3), I can add a step #3.5, which is to disable all the signaltaps other than the one(s) you actually need. That helped me to get rid off the 'Instance not found' errors.
