13 years agosignal spy in vhdl 2008
VHDL 2008 supports a direct hierarchical reference for signals. An example hierarchy is shown below.
A <= <<signal top_ent.u_comp1.my_sig : std_logic_vector >>; Signal 'A' can be used to spy on signal 'my_sig' in u_comp1 which is instantiated inside top_ent using the above hierarchy. However, there is a problem. modelsim is reporting error of 'unresolved reference to top_ent.u_comp1.my_sig' if the statement above is used inside a generate statement. SpyGenofA : if instantiateablock = true generate . . . A <= <<signal top_ent.u_comp1.my_sig : std_logic_vector >>; . . . end generate; However, if used outside a generate statement, it works fine. Any idea what's going on....?
