Hi Steady,
You say you are doing simulation on the design, from your saying on "can't find the node XXX", I guess you are doing gate/netlist level simulation. I seldom to netlist/gate level simulation, but I have little suggestion for you:
1. probe for node XXX*, normally after synthesis the node name will become xxx~combout or blabla
2. used the following synthesis option to prevent the node to be synthesized away: set_instance_assignment -name implement_as_output_of_logic_cell on -to <node name>
Also, as far as I know "signal probe" should be used for hardware signal probing/debugging.
