tedh4ddv
3 years agoSignal Probe - Source node does not exist
I've compiled my project. I've reserved an available pin for Signal Probe output. When I try to Add Signal Probe Pin, the selected node is not found. I see an error: Source node does not exist. P...
- 3 years ago
I changed node filter to post fitting and was able to select the target node. The design compiled and the node was accessible at the selected pin. Thanks for the advice.
ShengN_altera
3 years agoHi,
You may also try confirming whether that node exists or not by click View > Node Finder, and filter by Signal Tap: post-fitting to view the nodes you can route. Check this link https://www.intel.com/content/www/us/en/docs/programmable/683819/23-3/step-2-assign-nodes-to-pins.html
Sheng
tedh4ddv
3 years agoI changed node filter to post fitting and was able to select the target node. The design compiled and the node was accessible at the selected pin. Thanks for the advice.
