PhilipJ451's avatar
PhilipJ451
6 years ago
signal from input pin to output pin inverted
I am designing with Quartus Prime v19.1.0 for a Cyclone 10 device.
I have two clock inputs into the design and for convenience I feed these signals to output pins with test points connected (along with other signals for design analysis).
Dante_SCLK: in std_logic;
Dante_LRCK: in std_logic;
TP3: out std_logic;
TP5: out std_logic;
TP3 <= Dante_SCLK;
TP5 <= Dante_LRCK;
When examined with an oscilloscope, the signal 'Dante_SCLK' is inverted!!
This is highly misleading and results in confusion, mistakes and time wasted trying to debug why the design appears to be wrong.
Can anyone explain why this happens and what I need to do to stop it.
PhilipJ
1 Reply
  • PhilipJ451's avatar
    PhilipJ451
    Sorry All, ignore this!!
    Confusion with another part of the system (not FPGA) generating the signal the wrong way up, and me getting confused on the oscilloscope between 1/2 the period of the clock (~20nS) and the natural delay through the FPGA from input pin to output pin
    regards
    PhilipJ
