MoZdk
8 years agoShould Quartus 18.1 support FF creation by this: Q <= D when rising_edge(CLK); The D and CLK are input ports on a module, and Q is a output port. The Quartus 18.1 breaks with internal error due to this construction.
PLehm
8 years agoThis code line is standard synthesizable code.
It was specified in IEEE Std. 1076.6-2004 Clause 6.1.3.5
6.1.3.5 Edge-sensitive storage using concurrent signal assignment statements
A concurrent conditional signal assignment statement may be used to model an edge-sensitive storage element
provided that the assignment can be mapped to a process that adheres to the rules in 6.1.3.1.
Example:
COND_SIG_ASSGN: Q <= '0' when RESET = '1' else
'1' when SET = '1' else
A when ASYNC_LOAD = '1' else
D when CLOCK'EVENT and CLOCK = '1';More over it was supported by previous Quartus versions as this tool was called "Altera Quartus II".
Even if it's an unsupported syntax, a tool should never crash.
In addition, this syntax is supported by all competitors (I'm listing only synthesizer tools):
- Xilinx ISE
- Xilinx Vivado
- Lattice LSE
- Synopsys Simplify PRO
Kind regards
Patrick Lehmann
Vice-Chair of the IEEE P1076 Working Group
