11 years agoShort vs Int vs Floating Point usage in Kernels
I'm just wondering if anyone else has successfully used smaller fixed point representations for data in their kernels compared to floating point. By that I mean I'm playing around with changing my a...
11 years ago --- Quote Start --- That would also explain why the same algorithm with the boolean operator exploded in size. Would it be better to optimize fixed point kernels by loading/storing them as 32-bit integers (as 4 chars packed together) and then separating them only for the internal arithmetic of the kernel to keep the alignment at 4 bytes? Or would a char4 vector data type accomplish the same task? --- Quote End --- The boolean operator case is different. Because of the logical dependence, the second load operation has a control dependence on the first one. This uses a different (and more expensive) type of load/store unit. Yes, loading/storing larger types (int, or char4) would solve the alignment problem at the expense of wasted memory.
