10 years agoshift_left and shift_right for large vectors freeze Quartus
I am using Quartus 15.1.1 64 bit I just found that shift_left and shift_right for large vectors freeze Quartus analysis and synthesis y <= std_logic_vector(shift_right( unsigned(x), i));...
10 years agoI tried a 765 bit shift_right:
compilation time: 17 minutes fmax: 110 MHz on CycV There is Multiplexer Statistics report inside compilation: +------------------------------------------------------------------------------------------------------------------------------------------+ ; Multiplexer Restructuring Statistics (No Restructuring Performed) ; +--------------------+-----------+---------------+----------------------+------------------------+------------+----------------------------+ ; Multiplexer Inputs ; Bus Width ; Baseline Area ; Area if Restructured ; Saving if Restructured ; Registered ; Example Multiplexer Output ; +--------------------+-----------+---------------+----------------------+------------------------+------------+----------------------------+ ; 4:1 ; 253 bits ; 506 LEs ; 0 LEs ; 506 LEs ; Yes ; |signed_adder|y[435]~reg0 ; ; 7:1 ; 3 bits ; 12 LEs ; 12 LEs ; 0 LEs ; Yes ; |signed_adder|y[253]~reg0 ; ; 7:1 ; 189 bits ; 756 LEs ; 756 LEs ; 0 LEs ; Yes ; |signed_adder|y[103]~reg0 ; ; 10:1 ; 48 bits ; 288 LEs ; 288 LEs ; 0 LEs ; Yes ; |signed_adder|y[36]~reg0 ; ; 13:1 ; 12 bits ; 96 LEs ; 96 LEs ; 0 LEs ; Yes ; |signed_adder|y[4]~reg0 ; ; 16:1 ; 4 bits ; 40 LEs ; 40 LEs ; 0 LEs ; Yes ; |signed_adder|y[3]~reg0 ; ; 4:1 ; 64 bits ; 128 LEs ; 128 LEs ; 0 LEs ; No ; |signed_adder|ShiftRight0 ; ; 4:1 ; 64 bits ; 128 LEs ; 128 LEs ; 0 LEs ; No ; |signed_adder|ShiftRight0 ; ; 4:1 ; 317 bits ; 634 LEs ; 634 LEs ; 0 LEs ; No ; |signed_adder|ShiftRight0 ; ; 4:1 ; 16 bits ; 32 LEs ; 32 LEs ; 0 LEs ; No ; |signed_adder|ShiftRight0 ; ; 4:1 ; 16 bits ; 32 LEs ; 32 LEs ; 0 LEs ; No ; |signed_adder|ShiftRight0 ; ; 4:1 ; 653 bits ; 1306 LEs ; 1306 LEs ; 0 LEs ; No ; |signed_adder|ShiftRight0 ; ; 4:1 ; 4 bits ; 8 LEs ; 8 LEs ; 0 LEs ; No ; |signed_adder|ShiftRight0 ; ; 4:1 ; 4 bits ; 8 LEs ; 8 LEs ; 0 LEs ; No ; |signed_adder|ShiftRight0 ; ; 4:1 ; 737 bits ; 1474 LEs ; 1474 LEs ; 0 LEs ; No ; |signed_adder|ShiftRight0 ; ; 4:1 ; 758 bits ; 1516 LEs ; 1516 LEs ; 0 LEs ; No ; |signed_adder|ShiftRight0 ; +--------------------+-----------+---------------+----------------------+------------------------+------------+----------------------------+ Quartus use multilevel mux or this report is another thing?
