17 years agoThe correct way to specify the -max delay is to use tCOmax + Data delay max - Clock delay min.
The correct way to specify the -min delay is to use tCOmin + Data delay min - Clock delay max. Where Data delay is the time delay on the data trace as a result of board delays. Similarly Clock delay is the time delay on the clock trace as a result of board delays. Jake
