14 years ago
Setting INCREMENTAL_COMPILATION to "OFF" is no longer supported
I have ported an old design which was originally compiled using Quartus II 5.1, to Quartus II 11.1 SP1.
Analysis, Synthesis and P&R is now working OK, except for one Critical Warning which I can't get rid of:
critical warning (138069): setting incremental_compilation to "off" is no longer supported. assignment is ignored. to disable partitions, set the ignore_partitions global assignment to "on" instead.
I am not familiar with Tcl and do all assignments using the GUI.
I ticked the box "ignore partitions assignments during compilation" in the Incremental Compilation part of assignments, but have found no way of suppressing that critical warning.
I have searched for any occurence of "INCREMENTAL_COMPILATION" in files within the project directory (and its subdirectories), but no success.
Is there some global assignment elsewhere that sets INCREMENTAL_COMPILATION to "OFF"?
Thanks for your help,
Alex
    Hi.
    All project assignments should be in <project_name>.qsf file (more specifically in <revision_name>.qsf, but if it's your only revision then the names should match). You can search for incremental compilation assignment there.
    if you haven't defined any partitions, shouldn't the feature essentially be turned off?
    I agree that the feature should be off since there are no partitions in my design.
    But I was essentially wondering why I get that critical warning, and how to get rid of it.
    I have looked for an "INCREMENTAL_COMPILATION" entry in every .q?f file in the project directory (xxProjectxx.qpf, xxRevisionNamexx.qsf, assignment_defaults.qdf, xxRevisionNamexx_assignment_defaults.qdf): nothing.
    Actually, I get that "critical warning (138069): setting incremental_compilation to "off" is no longer supported. assignment is ignored. to disable partitions, set the ignore_partitions global assignment to "on" instead." message as soon as I open the project.
    Help!
    Alex
    ah ok i understand your problem a bit more
    can you grep through the source files as well? it's possible to embed Quartus settings in HDL
    I grepped for INCREMENTAL_COMPILATION through every files in the project directory (and its sub-directories), it's not there :cry:.
    Hi again,
    My problem seems to be sorted, after numerous fiddling. Unfortunately I don't know what exactly made the Critical Warning go away.
    At some stage I thought it was caused by an archived project (xxProjectxx.qar, which contained some INCREMENTAL_COMPILATION assignment) that had inadvertently ended up in a directory declared as project library. But to try and confirm it was caused by that file, I put it back in the library directory: the Critical Warning did not come back.
    Anyway, it seems to be sorted. Thank you for your help,
    Alex
    I had the same problem migrating from Quartus 7.2 to 11.1.
    Resolution was to remove INCREMENTAL_COMPILATION assignment in the <project_name>_assignment_defaults.qdf file, which was imported from my old design. It appears that this assignment is no longer be set in the .qdf files.
    Larry
