12 years agoset size of binary number?
How can the size of a binary number be set, or extended by zeros; i.e. equivalent of Verilog's <size>'b<value>. So in Verilog 5'b110 will give 00110b. I require the size to be adjustable in VHDL, because the code I am writing has a constant at the beginning of the program, and when the constant value is manually changed, the binary number size needs to change to compensate; otherwise the compiler says either the binary number has too little or too many bits. Thank you
