13 years agoSo there's no way they can be synchronously analyzed, so yes, they need to be cut.
Just as importantly(if not more so), your design needs to know they're being transferred asynchronously. For example, if both clocks were 100MHz, but just coming from different sources, and you try to transfer a 16-bit bus between the two domains, you will get garbage on the other side, as bits will be captured from different words(or bits will got metastable). The real question is if you designed for these transfers to be asynchronous. If so, then cut them. When making the change to the .sdc, do not re-compile to see if it took. Launch the TQ GUI, and do a report_timing on the paths. You should see them get reported. Then modify your .sdc to cut the timing. Double-click Reset Design, and then re-run your report_timing command(click the up arrow to get it from the log history). It should come back and say No Paths to Report. That means it was cut, and you're able to do a full compile to see how it affects place-and-route. But if the path shows up, you'll need to debug. In your case the false path was ignored, was applied to the wrong path, etc. I can't say for sure what happened though.
