10 years agoset_clock_groups not being applied to pll clocks
Greetings. Brand new to this forum so apologies in advance if this is not the correct subforum. Also brand new to Altera parts/tools so apologies in advance for everything.
I am using Quartus Prime Lite Edition 16.0.0 Build 211 targeting a Cyclone IV EP4CE55F23I7 I have 2 asynchronous clocks coming into the FPGA, which I defined in my SDC file with: create_clock -name TS_ipclk -period 31.000ns [get_ports {ipclk}] create_clock -name TS_clk -period 50.00ns [get_ports {clk}] set_clock_groups -asynchronous -group TS_ipclk -group TS_clk I pass the TS_clk signal through a pll, and its output clock eventually touches some CDC structures that cross into/from TS_ipclk. Even though I have declared the input clocks as asynchronous, they are still appearing as timing errors where the source and destination clocks are "inst5|altpll_component|auto_generated|pll1|clk[1]" and "TS_ipclk". I tried adding: derive_pll_clocks to my SDC file with no luck. Is there a way to have all timing analysis between asynchronous clocks disabled between the PLL clocks and TS_ipclk?2 Replies
You need to explicitly add the PLL derived clocks to the groups as in:
as shown in the Altera TimeQuest User Guide.set_clock_groups -asynchronous -group { adc_clk the_adc_pll|altpll_component|auto_generated|pll1|clk the_adc_pll|altpll_component|auto_generated|pll1|clk the_adc_pll|altpll_component|auto_generated|pll1|clk } -group { sys_clk the_system_pll|altpll_component|auto_generated|pll1|clk the_system_pll|altpll_component|auto_generated|pll1|clk } - Altera_Forum
Vivado has a -include_generated_clocks option for the set_clock_groups constraint to handle this case. That would be a nice addition for Quartus.
