15 years agoYou need Y, Cb and Cr if you are going to colour space convert to RGB. Setting Y to 0 just kills an RGB output. The conversion is done via a matrix transform. But depending on what your input and output are for affects the matrix.
Raw video off a DAC is likely to have Y values in the range 16 to 235. PC monitors often expect the range 0 to 255 for RGB for peak values, so you can either rescale the input to 0 to 255 or use a different matrix for the colour space conversion. The standard matrix for conversion is:
(R) = ( 1.0 , 0.0 , 1.140 , 0.0 ) (Y )
(G) = ( 1.0 , -0.396 , -0.581 , 0.0 ) * (Cb-128)
(B) = ( 1.0 , 2.029 , 0.0 , 0.0)) (Cr-128)
So
R = Y + 1.14(Cr-128)
G = Y - 0.396(Cb-128) - 0.581(Cr-128)
B = Y + 2.029(Cb-128)
