14 years agoHi Kevin Jennings,
Thank you for your help. Yes, my fifo is an asunc-fifo,there is no synchronous clk. When I added the the condition when read and write are both true the simulation result was the same as before.In fact in the test file in the attachment read and write will never be true at same time.Following is the rewritten one: begin if(!rst)usedw<=8'h0; else if(read==1'b1)begin if(write==1'b1)begin usedw <= usedw; end else begin usedw <= usedw- 8'h1;end end else if(write==1'b1) begin if(read==1'b1)begin usedw <= usedw;end else begin usedw <= usedw +8'h1;end end end
