9 years agoSDC - What clock should the input pin be relative to?
Hello, signal_x in an input pin to my FPGA. signal_x is synchronous to clock_x which is also an input pin. clock_x drives a pll input and becomes pll_clock_x. pll_clock_x is pha...
9 years agoI recompiled and ran it with the PLL set to source synchronous mode.
Unfortunately, the problem persists almost no change in the negative slack. The relationship is 5.000 I continued my investigation and looked into the chip planner. Perhaps what you see there may shed some light on the timing results. I marked the point of one of the failing input pins (blue x mark) and the PLL whose output is used to clock that pin (red x mark). They are pretty far away... What do you think ? https://www.alteraforum.com/forum/attachment.php?attachmentid=13375
