12 years ago --- Quote Start --- Thank you very much for your posts! Actually I forgot to check the posts after getting the first one. The idea with the Nios Shell was good. But unfortunately my script is in batch and I don't want to change to linux scripting. I will try to use the code from Jerry --- Quote End --- Hi vhdl_world, When you use the code, please note which only extract map's warning informations. Becasue different warnings are strored in different rpt files, so if you want to extract full compilation's warning info you should open all different rpt files and extract what you want from them.
