12 years ago --- Quote Start --- as mentioned above, you can use the Nios II Command Shell on Windows, which is actually a cygwin terminal. cygwin includes grep --- Quote End --- Thanks for you reply! Now, i can extract the information from the compilation reports thru using grep or using tcl codes.
