12 years ago --- Quote Start --- Good idea, thank you. As someone who does not (yet) use Nios, I was not even aware of the Nios shell. In my case, I use a Tcl script to do the build. Then your suggestion can be extended to: quartus_sh -t build.tcl | grep Warning --- Quote End --- Can you use this command under bach? For i can run "quartus_sh -t build.tcl", but can't run "quartus_sh -t build.tcl | grep Warning". Or is greq isn't of MS-DOS command?
