12 years agoSCFIFO Seems Dead in simulation
Hi everyone,
I am trying to build a LPF, an averaging filter in particular, so I used the FIFO MegaFunction, however, when I simulated the design in ModelSim it turned out that the FIFO is not accepting data and not spitting out neither. The output is stuck on 0 value (Check the screenshot). I tie up the 'read request' and 'write request' to one, so that it keep writing and reading on every clock edge.... is this correct? And of course, I added the 'altera_mf' library to ModelSim using this command:
vsim -L altera_mf -lib work testbench -t 1ps
And no errors on compilation. Any thoughts guys?
