Altera_ForumHonored Contributor11 years agoSCFIFO Seems Dead in simulation Hi everyone, I am trying to build a LPF, an averaging filter in particular, so I used the FIFO MegaFunction, however, when I simulated the design in ModelSim it turned out that the FIFO is not ...Show MoreScreenshot (180).jpg21 KB
Altera_ForumHonored Contributor11 years agocheck you haven't connected aclear instead of clock or post your fifo code
Recent DiscussionsInterfacing Avalon Streaming FIFO IP with GTS Ethernet Hard IPInvalid license key (inconsistent authentication code)Regarding the issue of UFM not startingram retimingReset Release IP for Agilex needs Stratix 10 device files installed!
