TN-Notebooks's avatar
TN-Notebooks
2 years ago
saving the examined data of Max V failed --- in the Intel Quartus Prime lite 22.1
Hallo
for repair purposes i need to clone Max V 5M80ZE64C5N
I do not need to change anything and do not want to programm anything - just need clones.
Installed Quartus Prime Lite 22.1
Created a Project by wizzard - selected the correct Chip
Open the Programmer - Add device - select chip
check the box for Examine and start
Progress 100 % success
fine until here
now i can not save the File
Right klick on "untitled1.pof - save File results in
and Quartus closes at all
same Issue like in Standard Edition and not solved for Lite Edition?
https://www.intel.com/content/www/us/en/support/programmable/articles/000094118.html
Report :
Problem Details
Error:
Internal Error: Sub-system: AFCQ, File: /quartus/gcl/afcq/afcq_file_dlg.cpp, Line: 378
QFileDialog layout has changed
Stack Trace:
0x25da6: AFCQ_FILE_DLG::create_checkbox + 0x66 (GCL_AFCQ)
0xcfd8: Ui_MDB_EXPORT_DB_DLG::setupUi + 0x448 (sys_mdb)
0xdbc5: MDB_FILE_NEW_DLG::MDB_FILE_NEW_DLG + 0x2b5 (sys_mdb)
0x7a476: PGMWQ_FRAME_WND::on_save_file_action + 0x36 (pgm_pgmwq)
0x1fb37f: QMimeData::urls + 0x13bf (Qt5Core)
0x6c96: QAction::activate + 0x136 (Qt5Widgets)
0x161d17: QMenu::actionGeometry + 0x457 (Qt5Widgets)
0x161b85: QMenu::actionGeometry + 0x2c5 (Qt5Widgets)
0x167298: QMenu::mouseReleaseEvent + 0xb8 (Qt5Widgets)
0x397d5: QWidget::event + 0x145 (Qt5Widgets)
0x16348b: QMenu::event + 0x17b (Qt5Widgets)
0x1737c: QApplicationPrivate::notify_helper + 0x13c (Qt5Widgets)
0x15080: QApplication::notify + 0x7d0 (Qt5Widgets)
0x1dae38: QCoreApplication::notifyInternal2 + 0xb8 (Qt5Core)
0x186e1: QApplicationPrivate::sendMouseEvent + 0x331 (Qt5Widgets)
0x618cd: QSizePolicy::QSizePolicy + 0x278d (Qt5Widgets)
0x5fb26: QSizePolicy::QSizePolicy + 0x9e6 (Qt5Widgets)
0x1531e: QApplication::notify + 0xa6e (Qt5Widgets)
0x5bf63: QGuiApplicationPrivate::processMouseEvent + 0x723 (Qt5Gui)
0x4726a: QWindowSystemInterface::sendWindowSystemEvents + 0x9a (Qt5Gui)
0x22835d: QEventDispatcherWin32::processEvents + 0xbd (Qt5Core)
0x5a4e8: qt_plugin_query_metadata + 0x1dc8 (qwindows)
0x1d6c60: QEventLoop::exec + 0x1a0 (Qt5Core)
0x1639c7: QMenu::exec + 0x1c7 (Qt5Widgets)
0x1637ba: QMenu::exec + 0x1a (Qt5Widgets)
0x39dc4: QWidget::event + 0x734 (Qt5Widgets)
0xdcb66: QFrame::event + 0x36 (Qt5Widgets)
0x243ce8: QAbstractItemView::viewportEvent + 0x318 (Qt5Widgets)
0xba7b8: AFCQ_TREE_VIEW::viewportEvent + 0x2a8 (GCL_AFCQ)
0x1dd703: QCoreApplicationPrivate::sendThroughObjectEventFilters + 0xe3 (Qt5Core)
0x17368: QApplicationPrivate::notify_helper + 0x128 (Qt5Widgets)
0x158b6: QApplication::notify + 0x1006 (Qt5Widgets)
0x62137: QSizePolicy::QSizePolicy + 0x2ff7 (Qt5Widgets)
0x1d9b2a: QCoreApplication::exec + 0x14a (Qt5Core)
0x10bb: qgq_main + 0x8b (quartus)
0x13538: msg_main_thread + 0x18 (CCL_MSG)
0x1484e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x18210: mem_thread_wrapper + 0x70 (ccl_mem)
0x12cf1: msg_exe_main + 0xa1 (CCL_MSG)
0x20c6: WinMain + 0x156 (quartus)
0x16d2: __scrt_common_main_seh + 0x116 (quartus)
0x17613: BaseThreadInitThunk + 0x13 (KERNEL32)
0x526b0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 22.1std.2
Build: 922
Edition: Lite Edition
  • Hi,
    After further checking, Quartus 23.1 for standard version will be release in Quarter 4.
    Hence for now, you can used to save the added ips file into the chain, so that it can restore how you added before. In this way, you can still use the previous added ips.
    Apologize for the inconveniences.
    Aiman
    • TN-Notebooks's avatar
      TN-Notebooks
      is there also a release Date for the 23.1 Lite version ?
  • Hi,
    Quartus Lite release will be the same as Quartus standard version.
    Aiman
  • I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
