TN-Notebooks
3 years agosaving the examined data of Max V failed --- in the Intel Quartus Prime lite 22.1
Hallo for repair purposes i need to clone Max V 5M80ZE64C5N I do not need to change anything and do not want to programm anything - just need clones. Installed Quartus Prime Lite 22.1 Created a...
NurAiman_M_Intel
3 years agoHi,
After further checking, Quartus 23.1 for standard version will be release in Quarter 4.
Hence for now, you can used to save the added ips file into the chain, so that it can restore how you added before. In this way, you can still use the previous added ips.
- When programming a device with ISP CLAMP enabled, the Intel® Quartus® Prime Programmer first looks for the .ips. The software only looks for the pin state information in the .pof if the .ips is not found. https://www.intel.com/content/www/us/en/docs/programmable/683786/current/saving-the-ips-file-information-to-the.html
Apologize for the inconveniences.
Aiman
TN-Notebooks
3 years agois there also a release Date for the 23.1 Lite version ?
