TN-Notebooks
3 years agosaving the examined data of Max V failed --- in the Intel Quartus Prime lite 22.1
Hallo for repair purposes i need to clone Max V 5M80ZE64C5N I do not need to change anything and do not want to programm anything - just need clones. Installed Quartus Prime Lite 22.1 Created a...
NurAiman_M_Intel
3 years agoHi,
While checking, we found that this problem has been fixed starting from Quartus 23.1 standard version.
Hence if you are using Quartus earlier than 23.1, you can used to save the added ips file into the chain, so that it can restore how you added before. In this way, you can still use the previous added ips.
- When programming a device with ISP CLAMP enabled, the Intel® Quartus® Prime Programmer first looks for the .ips. The software only looks for the pin state information in the .pof if the .ips is not found. https://www.intel.com/content/www/us/en/docs/programmable/683786/current/saving-the-ips-file-information-to-the.html
Aiman
- TN-Notebooks3 years ago
Hallo
i downloaded the 23.2 Pro Version ( without Licence ) and the QuartusProProgrammerSetup-23.2.0.94-windows
With both the Saving of examined Data works now.
But ISP Clamp is grey out and at File no Box.
Thomas
