9 years agoSame VHDL block RAM inferring file, different results
Hi, I have the following VHDL file to infer a true dual port, single clock block RAM. I believe that it is according to Altera's guidelines. I have Quartus 16.02 Build 222 07/20/2016. When ...
9 years ago --- Quote Start --- But there is a compromise solution that I tend to use. Generate the IP once using the wizard and then create a package with generics for the items of interest from the VHDL code generated by the wizard. For example, I have a dual-port RAM in my own code that looks like below. The entity is created by the wizard and I replace the hardwired numbers of the original with generics. It's not good for ROM, but for everything else it is MUCH easier than trying to deal with persnickety inference tools. --- Quote End --- This is a bit of a messy way to do things. Why not just instantiate the altsyncram directly in your code? You can get all the generics and ports from here: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_ram.pdf
