Thanks Rickard! Happy the workaround worked for you.
I have some extra data-points to share:
- Ubuntu 18.04 LTS on WSL seems to work without this workaround, while 19.04 and newer (including the latest 20.04 LTS) needs this workaround.
- If setting LD_PRELOAD while trying to start ModelSim compilations, they will fail to decrypt (and thus compile) any encrypted device libraries:
# ** Error: ../intelFPGA/20.1/quartus/eda/sim_lib/mentor/stratixv_atoms_ncrypt.v(38): (vlog-2163) Macro `<protected> is undefined. # ** Error: ../intelFPGA/20.1/quartus/eda/sim_lib/mentor/stratixv_atoms_ncrypt.v(38): (vlog-2163) Macro `<protected> is undefined. # ** Error: (vlog-13069) ../intelFPGA/20.1/quartus/eda/sim_lib/mentor/stratixv_atoms_ncrypt.v(38): syntax error in protected region. # # ** Error: ../intelFPGA/20.1/quartus/eda/sim_lib/mentor/stratixv_atoms_ncrypt.v(38): (vlog-13205) Syntax error found in the scope following '<protected>'. Is there a missing '::'? # End time: 23:08:09 on Aug 20,2020, Elapsed time: 0:00:00 # Errors: 5, Warnings: 0
The workaround is to only use LD_PRELOAD for Quartus tools, and not ModelSim. I have no idea why preloading udev would suddenly break the decryption but I can reliably reproduce the issue on a clean Ubuntu 18.04 and 20.04 machine (non-WSL) when setting LD_PRELOAD=/lib/x86_64-linux-gnu/libudev.so.1.
This is of course only relevant if you are using the 64-bit version of ModelSim. As Intel only distributes the 32-bit version to my knowledge that does not apply here.
Sorry that case had been idling for quite sometimes.
Could you try to install the latest Quartus version and see if the issue still persists? Please download the Quartus version with the corresponding OS from https://fpgasoftware.intel.com/
Try to follow the steps in Installing Windows Subsystem for Linux* (WSL) on Windows and please use Ubuntu 18.04 as stated in the user guide.
- bluecmd5 years ago
The latest version for Prime Standard is still 20.1 as far as I can tell. The behavior is the same for Ubuntu 18.04 and 20.04.
I use 20.1 on Ubuntu 18.04 every week and I have to use the preload workaround.EDIT: I see that I reported 18.04 as working an above post, but that's incorrect. I recall having that conclusion but I cannot remember why I thought that - I can clearly reproduce the issue on 18.04 and indeed I have to use the PRELOAD workaround every time I use Quartus.
In order to be 100% sure I did not mess something up, I made a new Windows user and did a fresh Ubuntu 18.04 LTS install.
I downloaded Ubuntu 18.04:
curl.exe -L -o ubuntu-1804.appx https://aka.ms/wsl-ubuntu-1804I installed it, and then did this:
$ /mnt/d/Sandbox/QuartusSetup-20.1.0.711-linux.run $ sudo apt update $ sudo apt install wsl dos2unix make libsm6 libxrender1 libfontconfig export DISPLAY=":0.0" # Launch Quartus and click "Specify license file" $ ~/intelFPGA/20.1/quartus/bin/quartus realloc(): invalid pointer Aborted (core dumped) # Try one more time, same action $ ~/intelFPGA/20.1/quartus/bin/quartus quartus: malloc.c:2868: mremap_chunk: Assertion `((size + offset) & (GLRO (dl_pagesize) - 1)) == 0' failed. Aborted (core dumped)As you can see, the issue is clearly there even on a fresh Ubuntu 18.04.
- RichardT_altera5 years ago
If I get you correctly, you try to launch Quartus from the Ubuntu 18.04 LTS installed in a Window 10 operating system? Why not you install the Quartus Window version directly? The WSL is for the Nios II EDS in Intel Quartus software.
