13 years ago
Running ModelSim in command-line mode
I write a testbench name test_FA.v. In the comman prompt, i go to test_FA.v directory and taip
1) vlib work
2) vlog test_FA.v.
3) vsim -c -do FA_run_msim_rtl_verilog.do FA -wlf waveform.wlf
However, I cannot see waveform.wlf created in the directory.Can anyone help me?
    Perform the same sequence in the Modelsim GUI first. You might have a problem.
    For example, although you create a work library, you do not map it, eg.,
    1) vlib work
    2) vmap work work
    or
    vmap work [pwd]/work
    If modelsim.ini already has a work mapping and it does not exist then you will see an error message.
    Also, I'm not sure that you have the names correct, eg., (2) has test_FA but (3) has FA, perhaps this is supposed to be test_FA?
    Cheers,
    Dave
    Sorry ,i taip wrong, act all is FA. Now i follow steps below but still cannot get the waveform.
    1) vlib work
    2) vmap work work
    3) vlog FA.v.
    4) vsim -c -do FA_run_msim_rtl_verilog.do FA -wlf waveform.wlf
    The contain of FA_run_msim_rtl_verilog.do as below:
    transcript on
    if {[file exists rtl_work]} {
    vdel -lib rtl_work -all
    vlib rtl_work
    vmap work rtl_work
    vlog -vlog01compat -work work +incdir+C:/altera/11.0/quartus/chapter2/exam2_3 {C:/altera/11.0/quartus/chapter2/exam2_3/FA.v}
    I still have 1 question, if i taip vsim -c in command prompt, the command prompt will become
    Modelsim>
    when i taip "wave create -pattern none -portmode input -language vlog /FA/cin" it shows "wave create not supported in batch mode" can I write the script as in modelsim GUI ?
    In the modelsim gui, simply type
    Modelsim> vlib rtl_work
    Modelsim> vmap work rtl_work
    Modelsim> vlog FA.v
    Modelsim> vsim FA
    Modelsim> add wave *
    Modelsim> run 10 us
    Your FA.v design should be a testbench, i.e., something that provides stimulus to a component. Normally you would have FA.v and FA_tb.v, where FA_tb.v instantiates the component in FA.v
    Cheers,
    Dave
    yes,i got no problem when running in GUI, but how can i simulate the same thing in windows command prompt?
    Put the same commands in a Tcl script, and run it.
    Though it makes no sense to create a waveform when using the command-line. For command-line mode, you typically run the testbench and check the exit code for pass/fail, then run the GUI for interactive debugging of the issue.
    Cheers,
    Dave
