14 years ago
running design example on altera
hi everyone,
am using altera cyclone III dev, this is very new to me.
if anyone know how to run design examples on altera pls help me.
if there are any tutorials regarding this pls suggest me.
thank you.
    Hi, you get altera cyclone III dev, there is an included "getting started" which is a good point to start.
    On altera web site > Literature, there are numerous pdf tutorials.
    hi sir/madam,
    thank you so much for your reply.
    am trying to run web server design example, there as soon as i launch sopc builder its not asking for create new system instead its showing open system and am encountering errors related to sd_ram_controller. if i disable that then there will not be any errors, it generates files. but while running those files am getting many errors.
    my question is
    can i disable components which are already defined?
    and files generated are are in Verilog HDL files i want VHDL files
    how to get VHDL files?
    any suggestions are appreciated
    thank you. . .
    Which version of Quartus & Nios are you using ?
    Could you post errors ?
    am using quartus II 8.1 and nios II system.
    am getting these errors as soon as i launch sopc builder
    Error: el_camino_sd_card_controller: Info: *******************************************************************
    Error: el_camino_sd_card_controller: Info: Running Quartus II Analysis & Synthesis
    Error: el_camino_sd_card_controller: Info: Version 8.1 Build 163 10/28/2008 SJ Web Edition
    Error: el_camino_sd_card_controller: Info: Copyright (C) 1991-2008 Altera Corporation. All rights reserved.
    Error: el_camino_sd_card_controller: Info: Your use of Altera Corporation's design tools, logic functions
    Error: el_camino_sd_card_controller: Info: and other software and tools, and its AMPP partner logic
    Error: el_camino_sd_card_controller: Info: functions, and any output files from any of the foregoing
    Error: el_camino_sd_card_controller: Info: (including device programming or simulation files), and any
    Error: el_camino_sd_card_controller: Info: associated documentation or information are expressly subject
    Error: el_camino_sd_card_controller: Info: to the terms and conditions of the Altera Program License
    Error: el_camino_sd_card_controller: Info: Subscription Agreement, Altera MegaCore Function License
    Error: el_camino_sd_card_controller: Info: Agreement, or other applicable license agreement, including,
    Error: el_camino_sd_card_controller: Info: without limitation, that your use is for the sole purpose of
    Error: el_camino_sd_card_controller: Info: programming logic devices manufactured by Altera and sold by
    Error: el_camino_sd_card_controller: Info: Altera or its authorized distributors. Please refer to the
    Error: el_camino_sd_card_controller: Info: applicable agreement for further details.
    Error: el_camino_sd_card_controller: Info: Processing started: Thu Mar 17 10:02:19 2011
    Error: el_camino_sd_card_controller: Info: Command: quartus_map not_a_project --generate_hdl_interface=C:\altera\suma\web_ser\webserver_c3\web_server\altera_avalon_sd_mmc_spi\ip_sd_mmc_spi_wrapper.vhd --source=C:\altera\suma\web_ser\webserver_c3\web_server\altera_avalon_sd_mmc_spi\ip_sd_mmc_spi_wrapper.vhd --source=C:\altera\suma\web_ser\webserver_c3\web_server\altera_avalon_sd_mmc_spi\ip_sd_mmc_spi.vhd --set=HDL_INTERFACE_OUTPUT_PATH=C:\DOCUME~1\user\LOCALS~1\Temp\sopcqmap35285tmp\ip_sd_mmc_spi_wrapper.vhd_temp
    Error: el_camino_sd_card_controller: Error: Can't find valid feature line for core SD_MMC_SPI_CORE (EC11_0002) in current license
    Error: el_camino_sd_card_controller: Error (10003): Can't open encrypted VHDL or Verilog HDL file "C:/altera/suma/web_ser/webserver_c3/web_server/altera_avalon_sd_mmc_spi/ip_sd_mmc_spi.vhd" -- current license file does not contain a valid license for encrypted file
    Error: el_camino_sd_card_controller: Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings
    Error: el_camino_sd_card_controller: Error: Peak virtual memory: 173 megabytes
    Error: el_camino_sd_card_controller: Error: Processing ended: Thu Mar 17 10:02:22 2011
    Error: el_camino_sd_card_controller: Error: Elapsed time: 00:00:03
    Error: el_camino_sd_card_controller: Error: Total CPU time (on all processors): 00:00:02
    Error: el_camino_sd_card_controller: Analyser output file not present: ip_sd_mmc_spi_wrapper.vhd.xml
    Error: el_camino_sd_card_controller: No definition of ip_sd_mmc_spi_wrapper in C:/altera/suma/web_ser/webserver_c3/web_server/altera_avalon_sd_mmc_spi/ip_sd_mmc_spi_wrapper.vhd
    if i disable el_camino_sd_card_controller then it generates system without any error.
    after that while executing top module i am facing these errors
    Error: Port "CSn_from_the_el_camino_sd_card_controller" does not exist in macrofunction "cycloneIII_embedded_evaluation_kit_web_server_sopc_instance"
    Error: Port "DI_from_the_el_camino_sd_card_controller" does not exist in macrofunction "cycloneIII_embedded_evaluation_kit_web_server_sopc_instance"
    Error: Port "DO_to_the_el_camino_sd_card_controller" does not exist in macrofunction "cycloneIII_embedded_evaluation_kit_web_server_sopc_instance"
    Error: Port "SCLK_from_the_el_camino_sd_card_controller" does not exist in macrofunction "cycloneIII_embedded_evaluation_kit_web_server_sopc_instance"
    Error: Port "WP_to_the_el_camino_sd_card_controller" does not exist in macrofunction "cycloneIII_embedded_evaluation_kit_web_server_sopc_instance"
    Info: Generated suppressed messages file C:/altera/suma/des_ex/webserver_c3/web_server/cycloneIII_embedded_evaluation_kit_web_server.map.smsg
    Error: Quartus II Analysis & Synthesis was unsuccessful. 6 errors, 88 warnings
    Error: Peak virtual memory: 352 megabytes
    Error: Processing ended: Thu Mar 17 09:47:54 2011
    Error: Elapsed time: 00:02:22
    Error: Total CPU time (on all processors): 00:01:07
    pls help me out of this.
    Hi, I see this is NOT a sd_ram_controller problem (as post# 3), but it is a license problem for el_camino_sd_card_controller.
    --- Quote Start ---
    Error: el_camino_sd_card_controller: Error: can't find valid feature line for core sd_mmc_spi_core (ec11_0002) in current license
    --- Quote End ---
    Check your license files.
    El camino sd_card controller is a third party component. Maybe license expired.
    thank you so much for your reply. . .
    that problem got resolved. . .
    i successfully downloaded that into fpga and i have selected correct .sof file even then when i tried to download it into nios ii it is showing this messege in the consol. . .
    Using cable "USB-Blaster [USB-2]", device 1, instance 0x00
    Pausing target processor: OK
    Reading System ID at address 0x08000200:
    ID value does not match: read 0x62C962CE; expected 0x54F17201
    Timestamp value does not match: image on board is older than expected
    Read timestamp 0:47:22 2010/12/22; expected 9:34:51 2011/03/17
    The software you are downloading may not run on the system which is currently
    configured into the device. Please download the correct SOF or recompile.
    Restarting target processor
    am not getting where i might have gone wrong. .
    pls help me. . .
    I means that you aren't using the same version of the sopc system definition for your software and hardware parts. Try to re-generate the SOPC system, recompile the Quartus project and recompile your software, in that order.
    i tried it. but it didn't work. it is showing the same messege in the console.
    hi,
    in nios ii v8.1 "nios ii c/c++ application and BSP templet" was not there so i uninstalled that and installed version 10.1, in that target connections are not accessable and in nios ii hardware consol it is showing the following messege,
    could not initialize class.com.altera.systemconsole.internal.plugin.jtag.aji.AJIcable
    what may be the problem?
    pls help me. . .
    hi,
    sorry it was not a problem. i didn't knew that "nios ii c/c++ application and bsp" templet is used only for compilation, i tried to run it on hardware so that problem had occured. . .
    now am facing a different problem. . .
    i downloaded web server hardware into fpga and tried to run hello word software program on nios ii. there are no errors nothing but the problem is, output is not getting displayed in the console.
    if anybody has idea where i might have gone wrong or what the problem may be, pls help me. . .
    thank you. . .
