15 years agoam using quartus II 8.1 and nios II system.
am getting these errors as soon as i launch sopc builder Error: el_camino_sd_card_controller: Info: ******************************************************************* Error: el_camino_sd_card_controller: Info: Running Quartus II Analysis & Synthesis Error: el_camino_sd_card_controller: Info: Version 8.1 Build 163 10/28/2008 SJ Web Edition Error: el_camino_sd_card_controller: Info: Copyright (C) 1991-2008 Altera Corporation. All rights reserved. Error: el_camino_sd_card_controller: Info: Your use of Altera Corporation's design tools, logic functions Error: el_camino_sd_card_controller: Info: and other software and tools, and its AMPP partner logic Error: el_camino_sd_card_controller: Info: functions, and any output files from any of the foregoing Error: el_camino_sd_card_controller: Info: (including device programming or simulation files), and any Error: el_camino_sd_card_controller: Info: associated documentation or information are expressly subject Error: el_camino_sd_card_controller: Info: to the terms and conditions of the Altera Program License Error: el_camino_sd_card_controller: Info: Subscription Agreement, Altera MegaCore Function License Error: el_camino_sd_card_controller: Info: Agreement, or other applicable license agreement, including, Error: el_camino_sd_card_controller: Info: without limitation, that your use is for the sole purpose of Error: el_camino_sd_card_controller: Info: programming logic devices manufactured by Altera and sold by Error: el_camino_sd_card_controller: Info: Altera or its authorized distributors. Please refer to the Error: el_camino_sd_card_controller: Info: applicable agreement for further details. Error: el_camino_sd_card_controller: Info: Processing started: Thu Mar 17 10:02:19 2011 Error: el_camino_sd_card_controller: Info: Command: quartus_map not_a_project --generate_hdl_interface=C:\altera\suma\web_ser\webserver_c3\web_server\altera_avalon_sd_mmc_spi\ip_sd_mmc_spi_wrapper.vhd --source=C:\altera\suma\web_ser\webserver_c3\web_server\altera_avalon_sd_mmc_spi\ip_sd_mmc_spi_wrapper.vhd --source=C:\altera\suma\web_ser\webserver_c3\web_server\altera_avalon_sd_mmc_spi\ip_sd_mmc_spi.vhd --set=HDL_INTERFACE_OUTPUT_PATH=C:\DOCUME~1\user\LOCALS~1\Temp\sopcqmap35285tmp\ip_sd_mmc_spi_wrapper.vhd_temp Error: el_camino_sd_card_controller: Error: Can't find valid feature line for core SD_MMC_SPI_CORE (EC11_0002) in current license Error: el_camino_sd_card_controller: Error (10003): Can't open encrypted VHDL or Verilog HDL file "C:/altera/suma/web_ser/webserver_c3/web_server/altera_avalon_sd_mmc_spi/ip_sd_mmc_spi.vhd" -- current license file does not contain a valid license for encrypted file Error: el_camino_sd_card_controller: Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings Error: el_camino_sd_card_controller: Error: Peak virtual memory: 173 megabytes Error: el_camino_sd_card_controller: Error: Processing ended: Thu Mar 17 10:02:22 2011 Error: el_camino_sd_card_controller: Error: Elapsed time: 00:00:03 Error: el_camino_sd_card_controller: Error: Total CPU time (on all processors): 00:00:02 Error: el_camino_sd_card_controller: Analyser output file not present: ip_sd_mmc_spi_wrapper.vhd.xml Error: el_camino_sd_card_controller: No definition of ip_sd_mmc_spi_wrapper in C:/altera/suma/web_ser/webserver_c3/web_server/altera_avalon_sd_mmc_spi/ip_sd_mmc_spi_wrapper.vhd if i disable el_camino_sd_card_controller then it generates system without any error. after that while executing top module i am facing these errors Error: Port "CSn_from_the_el_camino_sd_card_controller" does not exist in macrofunction "cycloneIII_embedded_evaluation_kit_web_server_sopc_instance" Error: Port "DI_from_the_el_camino_sd_card_controller" does not exist in macrofunction "cycloneIII_embedded_evaluation_kit_web_server_sopc_instance" Error: Port "DO_to_the_el_camino_sd_card_controller" does not exist in macrofunction "cycloneIII_embedded_evaluation_kit_web_server_sopc_instance" Error: Port "SCLK_from_the_el_camino_sd_card_controller" does not exist in macrofunction "cycloneIII_embedded_evaluation_kit_web_server_sopc_instance" Error: Port "WP_to_the_el_camino_sd_card_controller" does not exist in macrofunction "cycloneIII_embedded_evaluation_kit_web_server_sopc_instance" Info: Generated suppressed messages file C:/altera/suma/des_ex/webserver_c3/web_server/cycloneIII_embedded_evaluation_kit_web_server.map.smsg Error: Quartus II Analysis & Synthesis was unsuccessful. 6 errors, 88 warnings Error: Peak virtual memory: 352 megabytes Error: Processing ended: Thu Mar 17 09:47:54 2011 Error: Elapsed time: 00:02:22 Error: Total CPU time (on all processors): 00:01:07 pls help me out of this.
