10 years ago
RTL sequence to VHDL translation
How would i place this RTL sequence and convert it into VHDL
input:clk,mr,x,dat[6]
output:rdy,err,resa[3].resb[3]
registers;rega[3]. regb[3]
sequence:
0. regb<=000
1. rega <=dat [5..3]; =>(x=0)/(1)
2.=> (dat [2..0] = 000)/(5)
3. => (dat[5..3}> dat[2..0]/(6)
4. rdy =1; resa =rega; resb= regb; =>(4)
5. err =1; >=(5)
6.regb <=regb +1; rega<=rega - dat[2..0]; => (4)
control reset 0
    How much VHDL do you know? Try yourself first, then ask us to help on the points you are stuck on.
    Hi there, I know alittle to get me through RTL to VHDL conversion.
    The question i have is in regards to dat[6], is that written as data: In bit_vector (6 downto 0);
    For resa[3] and resb [3], is it related in this form:
    Architecture RTL_sequence to VHDL_translation is
    Port (resa , resb: OUT_bit (3 downto 0);
    or in
    SIGNAL resa: bit_vector (3 downto 0);
    resb: bit_vector (3 downto 0);
    your questions are not clear - have you worked your way through a VHDL tutorial?
