Pack_of_lone_wolves
2 years agoRouting constraints in QPP
I'm aware of Logic Lock feature in QPP, through which I can restrict the placement of a design node on the FPGA chip. How do I restrict the routing of a data path as well as a clock path in QPP? like...
- 2 years ago
This is all handled by clock and other timing constraints. I'd suggest getting familiar with your .sdc file.
User guide: https://www.intel.com/content/www/us/en/docs/programmable/683243.html
Training: https://learning.intel.com/developer/learn/courses/201/understanding-timing-analysis-in-fpgas, https://learning.intel.com/developer/learn/learning-plans/244/timing-analysis-with-the-intelr-quartusr-prime-pro-software
KennyT_altera
2 years agoIf you have high congestion within an area, my suggestion is to split out your logic into different area to reduce the congestion. May I know what device and Quartus version that you are using? As we have different method for different version and device.
