Rom ram IP core init files not supported on MAX 10 Error (14703)
Try'd add a small rom or initialized ram block on max10 project, resulted ni an error when building assembler file:
Error (14703): Invalid internal configuration mode for design with memory initialization
Error: Quartus Prime Assembler was unsuccessful. 1 error, 1 warning
Error: Peak virtual memory: 824 megabytes
Error: Processing ended: Thu May 2 14:05:19 2019
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01
Error (293001): Quartus Prime Full Compilation was unsuccessful. 3 errors, 156 warnings
- AnandRaj_S_Intel
Error is related to Invalid internal configuration mode
- Is tools configuration mode set to Single uncompressed image with Memory Initialization or Single compressed image with Memory Initialization?(Assignments->devices->device&pins->configuration->configuration mode)
- Is reset and exception vector memory pointing to On-chip RAM?
Refer below link
https://www.youtube.com/watch?v=0k4AZmdW9Sk
Anand
- RRomano001
Contributor
Hi Anand, Video refer to a NIOS application, I seen it use an SA device, I am using an SC04.
On this family is still present UFM but no initialized memory settings, just compressed uncompressed:
Project has no NIOS, I just need a small ROM or simply initialize ram when no processor on board.
As test, Rom where attached to Master sequencer. Master sequencer is controlled by An STM32 so here is simple to initialize ram or rom by DMA access or fire UDP send request a packet to load memory.
On design where fixed sequence are in place a small rom can reduce a lot LE usage.
I ask again JohnT about limit of SC family, I fear SC cannot support NIOS too.
Roberto
- AnandRaj_S_Intel
Hi Roberto,
Yes, We can use RAM IP and simply initialize ram when no processor on board.
With Is tools configuration mode set to Single uncompressed image or Single compressed image.
I have checked it using simple ram IP with memory size of 32 bytes of 8 bits data width & memory initialization as shown in image.
Can you share your design?
Anand
