Rom ram IP core init files not supported on MAX 10 Error (14703)
Hi Anand, Video refer to a NIOS application, I seen it use an SA device, I am using an SC04.
On this family is still present UFM but no initialized memory settings, just compressed uncompressed:
Project has no NIOS, I just need a small ROM or simply initialize ram when no processor on board.
As test, Rom where attached to Master sequencer. Master sequencer is controlled by An STM32 so here is simple to initialize ram or rom by DMA access or fire UDP send request a packet to load memory.
On design where fixed sequence are in place a small rom can reduce a lot LE usage.
I ask again JohnT about limit of SC family, I fear SC cannot support NIOS too.
Roberto
Hi Roberto,
Yes, We can use RAM IP and simply initialize ram when no processor on board.
With Is tools configuration mode set to Single uncompressed image or Single compressed image.
I have checked it using simple ram IP with memory size of 32 bytes of 8 bits data width & memory initialization as shown in image.
Can you share your design?
Anand
